Arc Flash Forum
Protective Device Bolted Fault & Arcing Fault Current Eqn
https://brainfiller.com/arcflashforum/viewtopic.php?f=4&t=4423
Page 1 of 1
Author:  Namgay Tshering [ Thu Aug 31, 2017 2:18 pm ]
Post subject:  Protective Device Bolted Fault & Arcing Fault Current Eqn
Iabr=Ia*IBbr/IB;
Iabr: is arcing fault current through each protective device
IBbr: is Bolted Fault Current through each protective device
Ia: is bus arcing fault current
IB: is bus bolted fault current
We can easily compute Ia & IB by IEEE 1584 equations, but I could not find Iabr & IBbr from the above equations. There are two unknown parameters in one equation. Can anyone share a complete equation, if you have please. You may find it in Annex D of CD ROM if you have a copy of IEEE 1584 2002 edition.
http://www.phpbb.com/
