Protective Device Coordination Analysis
Distance Learning Courses
$ 159.00 Best Value! Complete Course - 3 DVDs, Workbooks, 0.6 CEUs
This three part DVD series coves everything from an introduction to coordination and time current curves, to protecting transformers (based on ANSI C57), ground fault protection and overcurrent relays.
The DVD was recorded at the week-long Power System Engineering Class held several times a year by Jim Phillips, P.E. / T2G Technical Training Group
View a preview of Jim's "Protective Device Coordination Analysis"
From the Part 3 of the DVD series.
[ENTER BRAINFILLER STORE TO ORDER DVDs]
Each part of the Protective Device Coordination video series can also be ordered individually and includes a DVD, workbook and Continuing Education Credit.
Protective Device Coordination Video - Part 1 - $59.00
Part 1 introduces the concept of selective coordination, the data and analysis requirements, how to use time current curves, selecting a time current graph scale, and selecting settings of adjustable molded case circuit breakers.
You will learn how to determine the settings of adjustable molded case circuit breakers for optimal selectivity by creating time current curves. The video takes you through the steps required to construct time current curves.
Protective Device Coordination Video - Part 2 - $59.00
Part 2 shows you how to coordinate current limiting fuses, solid state circuit breakers and ground fault protection.
You will learn how to select circuit breaker settings to coordinate with fuses. See what the solid state breaker L,S,I,G settings are about and how to coordinate ground fault protection.
Protective Device Coordination Video - Part 3 - $59.00
Part 3 shows you how to protect transformers (based on ANSI C57), as well as fault protection using overcurrent relays. See how motor starting curves are used for motor protection.
You will learn how overcurrent relays operate as well as how to determine the amp tap, time dial and instantaneous settings. See how to use relay time current curves. This section utilized many examples and problems.
Earn 6 PDHs / 0.6 CEUs (Continuing Education Units) by completing all three video courses (or 2 PDHs/ 0.2 CEUs per video course).
Other T2G Distance Learning Courses
About the Instructor: Jim Phillips
For more than twenty-five years, Jim Phillips , P.E. has conducted over 1,700 live electrical training seminars for tens of thousands of people around the world.
Jim's unique teaching style and ability to answer the tough questions make complex subjects easy-to-understand. Class participants continually rate him as one of the best instructors in the industry. This is the course that other instructors attend to see how it's done!
Jim is a member of the IEEE 1584 Working Group "Guide for Performing Arc Flash Hazard Calculations". He has developed programs on topics such as Electrical Safety, Arc Flash Studies, Power System Design, Short Circuit Analysis and Protective Device Coordination Studies. Jim is also a contributing writer for NEC Digest - the official magazine of The National Electrical Code.
